Wiper motor issues
Norwester
Battle Ground, WA
C-10
In my '86, I decided to install a new wiper motor as my wipers were sooooo slowwww. I picked up a reman at the parts store and put it in with no problems.
Wipers worked good......and fast...for about 15 minutes and then they just stopped. I turned them off, drove home, and switched them back on. Worked fine.
Got up this morning and installed some new blades. Turned the wipers on and they stayed on for about 5 minutes and then stopped.
I disconnected the motor from the linkage and turned them on. They seemed to work fine except the motor was making a grinding, ratcheting type sound. I left them on for maybe 10 minutes and the motor ran fine.
I don't THINK I have a binding linkage problem as they worked fine before I swapped the motor. While I had the motor out, I grabbed hold of the linkage and worked the wipers by hand and they worked great.
Did I get a bad motor motor or do you think I have a linkage problem? Anything else maybe?
I wouldn't mind checking out the linkage.....before I start removing panels, can anybody tell how the access the it? Is it just under the cowl panel in front of the windshield?
Thanks in advance!
1973c10
Don
My guess is you got a bad motor that is getting bound up
when it gets warm under load
Norwester
Battle Ground, WA
C-10
I felt the motor when it stopped running and it was what I would call, "slightly warm"
No clue as to how warm it should get
Jarhead79
Mt Vernon il
Michael
I work at Oreillys and have heard that the remanufactured motors tend to be junk, haven't tried one myself yet but wanted to sometime. I'd return it and get another on, if it works awesome, if not I'd say it's something in the switch or wiring.
Norwester
Battle Ground, WA
C-10
I bought it at Autozone and suspect that the remans are less than reliable.
I just returned it.
I tend to think the electrical is ok as the wipers worked fine prior to replacing the motor, other than being pretty darn slow.
Jarhead79
Mt Vernon il
Michael
I understand, mine are slow also mines a 79' I want to try one of ours out from Oreillys and see if it works or not, good luck though!
Jarhead79
Mt Vernon il
Michael
I understand, my wipers are slow also mines a 79' I want to try one of ours out from Oreillys and see if it works or not, good luck though!
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Bad motor....
Georgeb
Wisconsin
George
K10 Burb Z71
Are you running them on a wet windshield with the engine running?
Norwester
Battle Ground, WA
C-10
Yes, George, I am. Very easy to do when you live in Washington State.
Norwester
Battle Ground, WA
C-10
Well, I went back to Autozone and ordered a new motor. Installed it and it works fine. Darn rebuilt parts!
alwaysbroken
