Wiper Arm Removal
Could someone explain to me in technicolor how to remove the wiper arms? I try to push on that tab, but to no avail....
Georgeb
Wisconsin
George
K10 Burb Z71
If you mean take the arms off the studs I believe they just pull off. I use a towel to protect the paint and use a spring bar or pry bar to pop them off....
The spring in the arm makes it tough. Pry up on the edge of the socket opposite of the the arm. Some arms even have a little spring loaded safety catch under there to keep it from sliding up past the shoulder recess of the stub shaft.
I tried to pull some off a junk cab today, but they were crappy looking, and I forgot my syringe to test the washer nozzles. I was trying to get some because the nozzles on mine are clogged. Have any of you had this problem?
Georgeb
Wisconsin
George
K10 Burb Z71
Yeah, mine were clogged on my 87. I blew them out backwards with compressed air and then washed them out inside with the tubes off. I took all the washer tubing and the nozzles off the arms and worked on the bench then put it all back on.
Dennis Blom
