Will they fit?
benjaminearle
Atlanta, GA
Ben
K10 LWB Fleetside
'97 L31 Vortec 5700
So, always hunting for deals, i find these wheels (see pic). They are supposedly off a mid-90s Toyota 4x4. 15x8.5.
From the pic and the description can anyone say that they will or wont fit a '79 4x4 with fulltime 4x4? If i put manual hubs in it, would they still fit? Is there a caliper clearance issue?
Speaking fo calipers, i hear that the Blazers have clearance issues. Are Blazer calipers a reasonable upgrade (usually a larger caliper is better) or are they, in the infinite wisdom of Detroit, just larger?
Oh, and can you put a 35x12.5 or similar on a 8.5"w wheel?
hirschdalechevy
norcal
rich
k-30
look's like they will fit. The bolt pattern for chevy half ton and toyota are the same the only thing you have to worry about is the center hole and from the pic it look's big enough. As far as backspace they look like they will be fine as well , (I have never had a problem with backspace with wheels with older half tons).As far as runnung 35s on 8.5 wheels , people do it all the time , (less chance of hitting the fender with a small lift). I have never heard of blazers having different caliper's. If you are not sure get out your tape and check out the backspace and hub size and compare.
The hurricane wheels I had on my old Burb were off a Toyota, I always knew they were just about the same and could be swapped from the 2, not sure on the backspacing question for the calipers, I personally never heard any problems.
benjaminearle
Atlanta, GA
Ben
K10 LWB Fleetside
'97 L31 Vortec 5700
Yeah, sorry about the double post.
I went back and read the bit about the blazer calipers and i think what that poster was trying to say is:
use disc brake wheels on disc brake trucks as wheels from a drum brake truck will not clear the calipers.​
I said yes to the wheels. Set of 4 for $125! And their current patina matches the overall condition of my truck.
On to a TBI350 now. Anyone want to buy an edelbrock intake and carb?
benjaminearle
Atlanta, GA
Ben
K10 LWB Fleetside
'97 L31 Vortec 5700
Yeah, that was what mad the 15s a little more attractive than 16+. I can swap the LT32 set that came on teh truck for $10/corner and wait to find a good deal on a lift, then good deal on LT35+ rubber.
I snoozed and lost a deal for a 6" spring and block lift kit for $250.
Probabbly better that i put that $250 towards reliability and safety at this point.
Dons79C10
