R8rPhan
- Feb 5, 2017
- California
- Mark
- 1973 (1979?)
- C10 long bed (Frankenstein truck)
About to order gaskets for the oil pan and valve covers..
Mainly I will likely be pulling the timing chain cover and replacing the seal/gaskets, possibly replacing the timing chain and gears...
I can order the cork gaskets, with separate front and back rubber crank gaskets, or they have these one piece rubber gaskets where everything is all in one (which means pulling the oil pan)...
Also there are cork vs rubber valve cover gaskets...
Which are better/easier/more reliable?
And to which surface should I be using sealer, block/heads or sheet metal pan/valve covers?
Thanks,
Mark
Thanks,
Mark
