Where can I buy coolant lines for a 4L80e?
itsallhistory
Ohio
Kevin
V2500
5.7 V*
One of the transmission coolant lines on my 91 Suburban is leaking. It's the 4L80e. Does anyone have a source for buying replacement lines? I think the original is bent and therefore can't make a proper seal anymore. I've looked online and can't seem to find any. Thanks.
itsallhistory
Ohio
Kevin
V2500
5.7 V*
Thank you. I'll take a look. Appreciate it.
I always make my own with 5/16 steel line from the parts store. The nuts and flares are correct for the trans and radiator.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
my 97 4l80 had a weird plug deal on the tranny side not like the old school flare nut
Oh yeah, the later ones have the quick connect fitting (although not often so quick to disconnect). IIRC, you can simply remove those fittings and screw in the old style flare nut fittings.
itsallhistory
Ohio
Kevin
V2500
5.7 V*
I'm going to use braided steel line and Russell fittings as well as the adapters from Sweet Performance. My next question is, what size are the fittings that go into the radiator? 1/2, 3/8, 5/16, or 1/4 inch? I need to buy the adapters for radiator to Russell -6 AN fittings.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
These are what I used to adapt the radiator to -6AN when I built my -6AN trans cooler lines. If you want Russel brand, you can just search for 1/2-20 Inverted Flare to -6AN fittings.
http://www.summitracing.com/parts/sum-220668n
Charkmapman
