When shutting truck off...
highdesertrange
kalifornia
mike
k30
most common cause for dieseling is to high of idle. highdesertranger
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
I've had backfire for to high of an idle. Lol in lowes hardware parking lot. Lady screamed across the parking lmao
Edhard_Stark
Connecticut
Ed
So as for the high idle/dieseling on my end, I throw the truck in park, and it high idles. I then disconnect the vacuum line going to the vacuum advance on the distributor and the idle goes back down to normal. Bad vacuum advance? Do I have to replace the whole dis.? Sorry but the old school engines are new to me, I have yet to fully tinker with one.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
What is your initial timing set at, with the vacuum advance disconnected and vacuum line plugged?
350runner
tx
Ceasar
Sounds like you have too much vac advance.
Edhard_Stark
Connecticut
Ed
8 degrees. However I should mention that the engine in my 79 is a center bolt engine from the late 80's, I don't know if that matters or not. Also, the vacuum advance and the vacuum line from the transmission go into a tee fitting, and both of those lines are drawn in through the single vacuum hookup in the front of my Edelbrock. I was told that I should have the trans portion plugged into the port on the intake. I don't know if that matters either.
350runner
tx
Ceasar
You can go ported as a quick fix out or figure out how much vac advance you have and limit it via stop plate
Edhard_Stark
Connecticut
Ed
Go ported? What does that mean? How can I check how much advance I have? What's a stop plate, and how would I adjust it? Sorry, I'm new at these distributors and carbs.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Ported vacuum only has suction when the throttle is opened.
At idle with hose disconnected, you won't feel any vacuum at the fitting.
Most carburetors have several ported vacuum fittings.
Edhard_Stark
Connecticut
Ed
Ok I'll look into that. Any input for checking the dis.?
350runner
tx
Ceasar
Edhard_Stark
Connecticut
Ed
Cool thanks guys. Should I mention that this happens when the engine gets up to operating temperature? When I drive around while the engine's cold, it's fine, but at operating temp it has this symptom.
350runner
tx
Ceasar
8dbtc really ain't much and could prob have more... but limiting the vac advance is key and this and detonation is why I will never suggest someone just hook up the vac advance not knowing how much advance it provides and where they are all in timing wise.
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
Hey my Cummins 5.9 has a dieseling problem should I be concerned about this? ? Hehe:p:p
350runner
tx
Ceasar
Yes very lol. If it can't tow it must go! Haaaa!
sparky77
