Wheel offset
Nick87scotts
Omaha
Nick
Scottsdale
I have an 87 1/2 ton with a 4in lift and 33/11.50s what offset do I need for my wheels to stick out about 2 inches
Driver4r
Nebraska
Trevor
k10,c20
Why do you want them to stick out???? Usually when they stick out its cause they have to or they will rub.
I have a set of 15x10's with a -47mm offset and they stick out roughly 1"-1.5"(the rim alone)
33x10.5's Can run on stock wheels most likely. I have currently 32x11.5-15 on 15x8" wagon wheels near factory BS.
And you wouldn't happen to mean Omaha NE what you?
Nick87scotts
Omaha
Nick
Scottsdale
I like the look of the stance, do you have any lift, and do you have any problems with rubbing?
And yes Omaha Ne
white lightnen
arm pit of SC
Ben
the more backspacing, meaning the further the wheels stick out, creates more leverage for bump-steer and is more strain on steering components.
\comes down to scrub radii, meaning your front wheels should pivot on center of tread, not roll in an arc.
if you are lifting your truck, get a angle finder and try to keep about 6 degrees of caster, meaning knuckle top leans toward back or truck. less will make it wander and look for things to run into, and it will be difficult to keep it going straight
That would be LESS backspacing that pushes the wheel further out.
Generally with these trucks, you don't want anymore than about 4.5 inches of backspacing, no matter what the rim width or geometry ends up being. With much more backspacing than stock, there's going to be clearance issues with brakes, tie rod, drag link, etc.
twzorek
