What would you pay for a nv4500 trans with use and wear, but functional when pulled
I dont know the rarity, but i know guys commonly swap this in to have that extra highway gear while also still having a Low gear. But the guy is asking for 500 and one of the gear has a "chip" out of it
TubeTruck
East TN
Denis
Suburban K10
LQ9
if it's a GM one they go for $500 with everything. I'd offer him $350 with the broken gear if I comes with the bellhousing and shifter. Dodge NV4500s go for $1500-2k here
SDJunkMan
Black Hills of South Dakota
Jeff
I am thinking of doing the 4500 swap, but thought the stock GM bellhousing that comes with the 4500 won't work with a squarebody.
eskimomann209
Modesto
Marcus
Damn even GM nv4500s go for 1100 where I’m at. That’s BS I need to head your way.
eskimomann209
Modesto
Marcus
Bell housings the same.
TubeTruck
East TN
Denis
Suburban K10
LQ9
I have no idea but Marcus says they are the same. I was just looking up prices on Marketplace.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Gm nv4500's just exist in my area.
Dodge nv4500's usually start at 1200 and go up.
SDJunkMan
Jeff
I thought the 4500 had a hydraulic clutch or was that just certain years? A hydraulic clutch bellhousing would have to be different than a bellhousing with an squarebody style mechanical throwout bearing.
SDJunkMan
Jeff
What makes the Dodge ones so much more expensive, are they better transmissions or just more in demand from Dodge owners? I thought that the GM and Dodge trannys were both pretty similar.
Vbb199
Salisbury NC
Vince
one of the two transmission's gear ranges are different if I'm not mistaken.
And some redneck lore indicates one of them is weaker than the other. I think the chevy nv4500 is more susceptible to some sort of failure than the other. Or maybe it's the other way around.
Generally the nv4500 is a favorite behind a Cummins... Which as you know is usually high valued.
Vbb199
Salisbury NC
Vince
I meant to say gm nv4500's don't exist.
eskimomann209
Modesto
Marcus
Ahh I see. I have done the swaps in the later square bodies. They had the hydraulic setup in them. I assumed (incorrectly) you guys were worried about bolt Patterns. I think it’s 85+ trucks are already hydro.
Another alternative is to drill the nv4500 to accept your linkage bell housing from the sm465.
eskimomann209
Modesto
Marcus
Early 90s chevys have a lower first gear. I think In 94 it goes higher. And dodge is the one with the nut that slips off and you lose OD.
Vbb199
Salisbury NC
Vince
There we go.
SDJunkMan
Jeff
I am also wanting to put mine in a 4x4 which I believe is supposed to have some clearance problems if using the stock 4500 bellhousing.
I really want to do this swap in the future, just having trouble getting facts on what stock parts will work without spending a bunch of cash on a Advance Adapters kit.
Brianall
