What size diff covers for 89 Blazer?
jo89k5
New York
Blazer
Want to put a fancier diff cover on my axles once I get the lift done, what size are the stock ones, I looked online and there are a bunch of options and I don't know off the top of my head, thanks
Swims350
Logan WV
none
count the bolts or take pics, best guess 10 bolts front and rear.
jo89k5
New York
Blazer
Yeah there both 10 bolt, but when I go to summit, there's like an 8.2 in, 8.5 in, does it matter? Jim
8.2 and 8.5 will interchange on the covers
You sure about that? The 8.2 in my Impalas look a lot different from the later 8.5 cover. I've never tried to swap them though.
It's an 8.5 front and rear, but the front is shaped a little different at the top, so it takes it's own cover.
jo89k5
New York
Blazer
Ok cool
Thanks alot everyone!
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
According to summit racing site the use the same cover so im thinking itll work the best best it to get one and see if the bolts line up and the buldge is in the right place for the gear.
The factory 8.2 covers have the gear oil gutter stamped into them that directs the lube into the axle tubes and out to the wheel bearings. Maybe that's the only difference.
Swims350
Logan WV
none
well if you order them and they don't fit they'd need replaced/returned, so I'd just get a front 8.5 with a plug in it and then a rear gm 10 bolt 8.5 and be done with it.
lmc has chrome ones and so does summit, I saw the cheapo chrome ones listed and plan to order some myself for both my axles.
sallyjeank10
