What is this?
Dadof2
Central Texas
R1500 Chevy Sub, C20
350 in both trucks
Or where does it go?
Thanks.
MrMarty51
Eastern Montana
Martin
Vacuum hose.
Most likely for the transmission modulator valve, right hand side of an automatic transmission, towards the back.
Judging from how durteee it is.
MadOgre
NA
NA
NA
NA
NA
No its the vacuum line that the climate control uses. It goes to manifold vacuum on the engine.
The transmission modulator valve uses engine vacuum from the manifold.
Dadof2
Central Texas
350 in both trucks
Appreciate it!
MadOgre
NA
NA
NA
NA
NA
Oh that could be too. My climate control vacuum line is in approximately the same spot.
Dadof2
Central Texas
350 in both trucks
Y'all are just damn awesome :cheers:
Do you have that valve in there?
chengny
87R10_Cruising
