What is this wire? It burnt threw.
GunMan9
Yorktown
Brandon
One of the fusible links in the power feed/charging circuit. Where does it trace to, the block on the firewall?
GunMan9
Yorktown
Brandon
Yes my truck won't start at all now. How do I fix it the easy way
You can cut it out and put an inline 30 amp fuse, use the same gauge wire/fuse holder. You can order replacement fusible links to keep it factory looking. That went bad on mine at the alternator and that mod got me buy. If you are out on the road stuck somewhere cut it out and wire it up direct to get you to safety, but get a fuse in that asap.
Some of those go bad just with age. If you think that happened all of a sudden from a power draw or short DO NOT WIRE IT TOGETHER DIRECT.
GunMan9
Yorktown
Brandon
Do you have any idea what guage wire it is. How do I connect the two wires at the bottom or do I just join them together and use a butt joint to connect them to the fuse link
GunMan9
Yorktown
Brandon
No it has been on its last leg for awhile
Best way to do it is solder it, butt joint is a last resort, I'd rather use a wire nut than a but joint on that gauge wire and current. Somebody will chime in on the wire size, I got to run. Maybe 12 gauge?
GunMan9
Yorktown
Brandon
I can solder it and heat shrink wrap it. Also I noticed this was bad but have no idea what it is.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Find out why that burnt up before you connect it.
in the pic, is a Thermal Vacuum Switch(TVS)
GunMan9
Yorktown
Brandon
It was like that when I got it. Still connected just looked like a lot of wear and tear
GunMan9
Yorktown
Brandon
Is the TVS hard to change
Driver4r
Nebraska
Trevor
k10,c20
Nope, pull the vacume lines off, deepwell socket(might be a special socket), screws out, replace.
And im gonna guess 10ga.
That's a TVS (thermal vacuum switch). It has a sensing bulb that is in contact with the engine coolant.
When the coolant reaches operating temperature the valve opens and applies vacuum to the EGR valve. I think - it might also operate the EFE (early fuel evaporation) valve.
It's hard to tell from the image and without the emissions code (maybe YFC, YFD, YJM) that is shown on a sticker located on the radiator support.
On the falied wire - it looks like the fusible link is still intact. The wire leading into it appears to have been already butt spliced at some point.
Like 89Suburban suggests, butt splicing anything in that circuit is a bad idea.
It looks like there is enough of a stub left to allow you to do a strip, solder and heatshrink repair procedure.
If that lead is the one that goes up to the junction block on the firewall - and it's hard to say from the image - it is a 1mm wire (= 16AWG).
GunMan9
Yorktown
Brandon
The top of the splice leads to a fuse junction that leads threw the fire wall
GunMan9
Yorktown
Brandon
Here is another pic it's hard to see.
