What is This? Thinking cruise
Camar068
10 yrs Air Force
Blue green an blue/black. There's a plug the to disconnect close to the firewall as well. Sorry for not looking it up....neck deep in ls swap.
Camar068
10 yrs Air Force
Way off...something to do with 700r4 trans
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I know I've seen this connector before. I went to check the car, but I didn't see one. TCC lockup is pink, green/white, tan/black. I must have seen it in the Jimmy, but it's not with me and won't be for several days. By then I'm sure someone else can find it in theirs or peruse the diagrams. Unfortunately, I'm a bit pressed myself with finals.
Camar068
10 yrs Air Force
no biggie, I did the smart thing and disconnected it BUT I plugged it into the transmission for further identification. Only 3 wires in the pic, and only 3 wires going into the trans, so your probably right.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
It’s a combo of torque converter lockup system for a 700r4 and cruise control. I recently upgraded from the crap and got a painless lockup kit.
Edit: now that I look at it closer it looks like it’s just the lockup system. Do you have a cruise button on your turn signal stalk?
436'd skylark
VT
Joe
2500HD
Durajunk
The only wires going into a 700r4 would be for the torque converter clutch and the vss if it's an electric speedo. The cruise control wouldn't have anything to do with the trans.
Camar068
10 yrs Air Force
I have cruise, wasn't functional though. Thanks guys
PrairieDrifter
North Dakota
Mason
They run in the same harness going through the firewall, at least mine did pretty positive they both get some kind of feed off the brake light switches to be able to shut off the cruise control as well as the switch on the turn signal stalk would tell the transmission to kick off of cruise. I had a dual switch setup which I believe is only for cruise.
PrairieDrifter
North Dakota
Mason
I didn’t specify, there aren’t any other wires except for the lockup going down to the trans, but the cruise system intermingles with the lockup system
436'd skylark
VT
Joe
2500HD
Durajunk
The ecm controls the lock up. The converter unlocks once the brake pedal is pushed with the cruise on or off.
PrairieDrifter
North Dakota
Mason
Pre computer controlled
mattyb
