what is this plug?
curse
49002 portage mi
kyle
My crate motor has a distributor in it with this plug but the truck harness does not have the other end. Am I going to have to use a distributor without this plug?
350 w/203
If I'm not mistaken, that's a plug for a dizzy that has an Electronic Spark Control. Just let it hang.
curse
49002 portage mi
kyle
I'll try letting it hang and see what happens. Thanks.
Moderator
Does the distributor have a vacuum advance can on it?
curse
49002 portage mi
kyle
Yes it does
350 w/203
That needs to be hooked up to a vacuum port.
curse
49002 portage mi
kyle
I know. I got all new vacuum lines and haven't ran them yet.
RoryH19
Rory
R10 Silverado SWB
The plug is for the electronic spark control, ESC. It was used in the 80's and most people bypass since they are faulty.
Here is a writeup I used to bypass mine before I did a LS swap.
http://www.73-87.com/7387garage/drivetrain/escrepl.htm
Basically you need to cut and splice the black and green wires together.
highdesertrange
kalifornia
mike
k30
I never knew they came with both vacuum advance and Electronic Spark Control(ESC). I always thought it was one or the other. learn sumptin everyday. highdesertranger
Moderator
There were some that didn't have a vacuum advance, but those were in some models of cars.
77Heavyhalf
