What is this part called?
MisterB
Northwest
AJ
GMC K2500 4X4
I already put a new brake proportioning valve and gasket in (the white plastic connected to brake booster), but I'm wondering what the other part is called and what it does?
Sent from my SM-N975U1 using Tapatalk
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Check valve?
Ewhitaker0020
I'm thinking it's a check valve. Hopefully someone can be more specific
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
That should be it, allows vacuum to be held in the booster so if engine is off or dies, you have some boosted braking left to get to a stop.
My truck doesn't have that anymore, just a plain hose to the manifold.
I think modern boosters have an internal check valve. You can hear the whooshing if you apply brakes with the engine off, then it's gone and the brake pedal gets high and tight.
MisterB
Northwest
AJ
GMC K2500 4X4
If it's a check valve, I wonder how it differs from the white check valve that's connected to the booster? Makes me wonder if the bigger black one is necessary or not.
Sometimes my brakes behave as though the booster doesn't have enough air to assist with stopping the truck. If I release the brake and apply it again, I typically get full power brakes. I figured it was cheap to replace that white check valve, so why not. Have no idea how old the original one was anyway. Wasn't sure if the other part should be replaced too (or eliminated if not a stock part or necessary)
Rusty Nail
Rusty
350sbc
Neat.
Learned somethin.
Booster filter
After you get another one, will you open it up and show us what's inside?
I bet it's got a bronze screen in it with honeycomb shapes like a cat convertor.
Aluminum ring that holds the halves together...
RoryH19
Rory
R10 Silverado SWB
Neat.
Learned somethin.
Booster filter
Exactly, helps filter the fumes coming off the intake/carb.
MisterB
Northwest
AJ
GMC K2500 4X4
Neat.
Learned somethin.
Booster filter
You bet. Thanks for the help
80BrownK10
Greenwood, SC
Nate
Check valve?
Yep. Was going to say it, but you are correct as I am sure all the other guys who beat me to it are as well.
But to the OP another one saying check valve.
80BrownK10
Greenwood, SC
Nate
Well looks like I'm wrong to.
Rusty Nail
Rusty
350sbc
:facepalm:
LoL
:nono:
MisterB now that im thinkin about it, I believe you may be the guy that taught me that trick.
Works good.
BUT! Next time i'll not try to be so damned helpful and post the link, i'll just play it cool like I know a bunch of cool ish like booster filter and ...ish.
Lol?
Lookit thurr
hoagster
California
K10, 1500
5.3l
F'n crack me up! That filter was pulled off of about 95% of the squares as a pos part long ago!! get a longer vacuum hose and eliminate that pos!
btrain04
