Started in on the drum brakes. Got it all off and layed out so hopefully I can put it back together right. Lol
Glad I got new cylinders. These are trash. Clean and reassemble.
I'm missing the little concave washer for the back of the pin that holds shoes in place tho.
Guess I'll go get a couple new ones from the parts store.
With as much rust as you have in the that cylinder, flush the brake lines with new fluid before putting it back together, or you are just going to ruin your new parts. Than do a really good brake bleed...It's your life, don't screw around and try to go cheap...
Ken B
indiana
ken
I got brakes and fuel 100% done, installed rear wiring, and put on new shoes....needed to see something for motivation!
@TotalyHucked , Is your truck on a lift AT the exhaust shop?...Never seen an exhaust shop THAT CLEAN, if so??? The guys Mom must run the place??!!!....LOL
Haha yep. Place is a little dingy, but nothing like most exhaust shops. This is a nice place
Sent from my iPhone using Tapatalk Pro
Catbox
Peter
C20 Silverado Camper Special
Header install day 1.
Passenger side Camaro/Chevelle/Nova big block header fits like a champ.
Using a later model gear reduction starter will help with heat soak as it is much smaller than the stock old school starter.
Today for part 2, we will work on fitting the driver side header.
Since nobody seems to ever post about putting these headers on a stock manual truck here we go.
Currently the header is bolted up using the front and rear bolt holes and the clutch Zbar fits and works as it should.
It is just close.
We removed the header after marking the rear tube where it needs a bit of torch and hammer work to be 100% sure it will not have any issues.
idahovette
Weiser Idaho
Perry
K20-K10
@TotalyHucked It all depends on the people working there, I guess. Pride in ownership and all that. When I had my shop, my partner was the exhaust guy, but I ALWAYS cleaned up after him, just cause. Kind of anal retentive about my space! Also. looks like a nice job on the system, too!!
Catbox
Peter
I like the placement of the exit pipe.
And how does it sound?
78C10BigTen
pennsylvannia
C10 BIG TEN
Finally got it looking half decent from about 30 feet! Little man helped me out. Primed it all, almost ready for my budget paint job. Getting rhino liner off....such a pain. Think twice before applying it.
Happy lookin lil fella! Glad he enjoys the square with ya. I like your truck.
Curt
Loco Hills
Curt
K-30
New tie rod installed.I like the way this is set up for adjustment.Seems beefy.
Catbox
Peter
Junior just brought this in to show me.
'Purently the PO didn't like the stupid EGR valve either.
They used a Diet Pepsi can to block it off and also filled the thing with weld.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
I was not smart enough to be that creative - I just bought another EGR valve. :D
HOTFOOT
northwest ct
michael
gmc k3500 srw
Ordered tanks for my k3500 and one came in banged up :mad: bottom pushed up so the sump (fi) doesn’t sit flat on the bottom and missing o ring and lock ring. Let the madness begin on filling a clam. Not sure where the used coffee and ice packs came from.
Dennis Blom
