Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Put my Mistress up for sale....offered it to a few hard core SB guys here. We'll see what happens....
Why are you selling it? What happened?
Vbb199
Salisbury NC
Vince
Rear bumper.Extremely happy with it!I did have to mount my plug for trailer.Got a trick hole saw set awhile back.Made short work of the 5/16” plate.Good quality.
Man,what a difference that DUI ignition parts made!I had a accel module and gm performance rotor and cap....night and day difference.
I still see your tag number :p
You might want to put some anti seize compound on prior to reinstallation this time.
Sent from my moto g power using Tapatalk
Yep, did that! Like usual, it ended up everywhere too.
You can always do what Discount Tire does. Get a brass wire brush for drill and use around lug bolts on hub and also on wheel in areas that contact. Might help.
Yep, did that too!
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Had to move it because I needed to chop back some dead bush because it was sticking me when on driver's side front fender.
Noticed that the radiator leak has gotten worse so it looks like I'll be buying a new radiator with electric fans sooner than expected. I wanted to do that anyway but not right now. Lol
Any recommendations on one for a BBC?
Also I found out that my blower motor for the heater works. There's no wire to the pos side of motor. When hit with 12v it kicked on tho.
Need new heater core and figure out how to get the blower to work from inside the cab.
Just kinda lost interest in it...I want my Extracab up and running. Plus that has always been the plan....Get it back together, and one day sell it, to finance the Extracab
hoagster
California
K10, 1500
5.3l
Worked on the front lighting harness which also has wipers, horn and brake pressure. So for those that have dealt with the wire going to the proportionate valve how was it routed and why do I have two splices, connections. The wiring diagram shows one plug (highlighted) I have an extra as seen in the photo. Someone got smart and added a test area? Anyone know how this wire was routed and secured. the two wire tie things are in the photo.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Mine has a short pigtail that goes from the valve to a metal clip on top of the left frame rail that holds the plug from the main harness. If you need a picture it will have to wait until Monday.
Scandia
