bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I looked and looked all day to try to figure out what to change. Came up with nothing. I love it just how it is. Well, other than the brake fluid leaking, antifreeze leaking, and the parking brake not working. I guess I should have been concerned with that stuff today instead of aesthetics.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Tightened the lower radiator hose clamp by the water pump, and snugged 1 water pump bolt.
Saw some drips running down the lower hose - would really prefer to not have to do the water pump again, so hopefully this gets it.
Also sprayed some engine cleaner, did some Seafoam spray in the carb, and topped off the oil.
Rough stuff, but someone has to do it.
Kim Burke
Northern IN
Kim
C1500
Dropped in the 5.3 in mine,friend of mine did a good job of routing the wiring harness in a clean way.now waiting for the 4L60E transmission being rebuilt
Pics, PLEASE!!
Kim Burke
Northern IN
Kim
C1500
Knocked the summer grime off and put a good coat of wax on to help repel the winter crud that will be here before we know it.
Admire, Admire, Admire, that's a fine piece of machinery!
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
I already filed a claim. It was a 13 subaru. It actually did tweak my bumper :( it kinked it up twords the center and the tailgate wont go down all the way
Well there's the problem. You got that fancy chrome bumper on there.
Did that snowblower block your view?
42Grand
Josh
I’m getting the truck all dialed in (as much as possible at least) to get ready for GoodGuys and Dino’s this weekend. I got my door panels almost put back together, painted 2 wheels and cleaned all the center caps. Still got a ways to go!!
78C10BigTen
pennsylvannia
C10 BIG TEN
Ooooohhhhh!!!!! Same fancy panels as mine except mine arent wood grain. Very nice!
42Grand
Josh
The top is the original insert, the second came off of the panel in the picture. I bought them because they weren’t all rotten like my original ones. I’ve got the wood insert between the passenger ac vents and I didn’t want the chrome in the doors. I bought some wood grain vinyl from amazon for $8 and trimmed the chrome inserts out. I love the way it turned out!! Thanks!!
73c20jim
Sierra Vista, AZ
C20 2WD Custom Deluxe
350 CID 195/260 HP Goodwrench crate
Started the full of piss and vinegar, ready to take on the world.
Attach new fan switch to AC controller. Took a while to find the little screws. Installed.
Attached orange wire from AC controller to orange on fan switch.
Turned on VENT MODE. Nothing. Will check fuse tomorrow. Need to drop the L side vent tube anyway to see fuse. STRIKE ONE.
Undaunted I moved on.
Tried to install stock AM-FM Cassette radio. L side vent tube in way. STRIKE TWO.
Tried to install new long battery bolts. Too long. STRIKE THREE.
That's it. I quit. Hope it's a better day tomorrow.
SDJunkMan
Black Hills of South Dakota
Jeff
Getting back to work on my 80. I was going to put a utility body on it years ago, but really don't have a need for the utility body now days, not to mention I would have to get rid of the side tanks to get it to fit right. Pulled it back off and am going to start cleaning up the frame and installing new springs.
Gurn
