Moderator Administrator
Havent got it back in yet, nor have I fired up the motor for the first time yet...getting there though!:cheers:
Just don't forget to stab a screwdriver down the dizzy hole and pre prime the oil and get some thru the bearings before stabbing the dizzy. I think someone got off with but I at one time had a cut off long screwdriver that worked well in a cordless drill and I'd spin it until oil came out of the oil pressure gauge port.
cbrodine
NW Ohio
Collin
C25
Yes Sir! I planned on that fo sho!!
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
change my oil cooler lines today what a messy job , don't matter how hard you try oil gets every where. I removed the diverter adapter and placed new gaskets cut the hydraulic hoses off and kept the aluminum lines and ran new hoses, here are all the pics.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
a couple more pics
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Keep a close eye on those lines for leaks. I think bad oil cooler hoses are what killed the engine in my truck before I bought it. One of the rod journals on the crank was so probably worn down 80 or 90 thousandths, I'm guessing it was because of low oil pressure. The entire underside of the truck was coated in a couple inch layer of oily dirt.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
yea I am gonna probably change those clamps out and use these
caliphatman8123
Bakersfield, Ca
Sam
v1500 suburban
tbi 350
What kind of line did you use? I'm thinking of redoing mine...
Sent from my SAMSUNG-SM-N900A using Xparent BlueTapatalk 2
Driver4r
Nebraska
Trevor
k10,c20
I upgraded My ground wire from the battery to chassis from 14Ga. to 4ga. Theres deffinetly a difference in size.
Then I drove her for awile, thats more of a luxury nowadays.
raylanr
Campeche, MEX
Franc
My 2.5 year old burn herself with the cab light bulb because it didn't had the cover, today I got it and put it in to prevent another accident
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
did this today , now I have somewhere to put stuff
had to do a lot of cutting and trimming.
You need to get with Retro and get you one of those overhead consoles like out of a Burb. 89S has a couple, and Shawn has spoken for one of them. I'm going to have one in blue. I don't care for the sliding doors much, but I figured it's a good place to stash a small semi auto pistol and a couple loaded mags in the other. And the lighting is pretty cool.
raylanr
Campeche, MEX
Franc
Is been sitting on my garage we got one from WAP a while back when Foamy come with us, I even have the headliner section with the. It out for it. If he can make it Saturday to come help me do some maintenance on it, we will test it to make sure it works before it goes in
Sent from my iPad using Tapatalk
raylanr
Campeche, MEX
Franc
And I saw another Burbank last time with one of those consoles, I really thought about getting since they are some kind of rare
jreed
Dalllas
Jonathan
1500 Silverado
I bought my C10 3rd Gen hoodie today!!
http://teespring.com/3DC10
They need atleast 200 orders to print the shirts/hoodies..got on it fellas!
They are making them for all the gen c10's
dan86
