Got the wiring part done on the under hood reel light but 3 of us in the family were sick today so I did not get it put in the truck. :/ hopefully in a day or two.
Driver4r
Nebraska
Trevor
k10,c20
Diesel helps clean out an engines oil system also.
I'm not sure why that's so blurry
That's OK, I took my glasses off and could read it just fine. :rofl:
Is that a Sea Foam rep saying this about the ounce per gallon? You know they want to sell Sea Foam, so they've probably tested it in one of their lab vehicles. I doubt it can hurt. I'd say that's for a very dirty fuel system, like a vehicle that has sat for quite a length of time. I'd say there are methods for routine maintenance, then there's this method for a deep cleaning. If it were me, I'd be willing to give it a try, but I just don't think you need 40 gallons of treatment. I don't recall the oz in a can now. But if it's 8oz, I'd probably buy 3 cans, get your tank close to Empty, put 20 gallons in and install 3 cans of Sea Foam. I think I'd poor a can in, put in about 8 gallons, pour another can in pump another 8 gallons, pour the 3rd can in and then pump the remaining 4 gallons. This way you can hope it's getting mixed well in the fuel. Then go for a drive and shake the wheel back and forth and pump the brakes for some quick stop and go to mix it well. The reason I say 20 gallons, is cuz even on Empty, you will have some gas in the tank and you'll want to be sure to have the 1oz - 1gal ratio as he's suggesting. That should give you 20 gallons of fuel system cleaning while you drive. I do know for a fact Sea Foam works. I've seen inside some crankcases that were pretty dirty. After Sea Foam crankcase for 500 miles, I could tell it was cleaner and did another treatment again 500 miles before the next oil change and that motor ended up pretty damn clean inside.
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
Sea foam test is in effect
With the fact the truck sat for ten years prior to me getting the truck I would classify this as a DEEP clean
So I put 32 oz in the tank and filled up... Tank is FULL (40gal)
I put the 8oz in the crank
I'll keep you updated on my thoughts.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Drove my square on Saturday. Had to adjust the base idle. I had adjusted the idle and choke when it was cold but now that it is warmer the choke was completely off and I had the base idle too low.
Put a sliding rear window latch from the "Help" section of the auto parts store on. I installed the screws and the very first time I latched it it broke. Stupid piece of junk.
Also tried out a new drivers side window switch. My passenger side window only works from the passenger side. New switch didn't fix it so it looks like I gotta chase down wiring issues.
And a trip back to the auto parts store to take back the switch and the busted latch.
man that seems like a LOT. I hope it doesn't do any damage...
Carb'ed Vortec 350
I hauled some tree branches to the green waste facility and got some vegetables and some seeds to plant a garden. Going to try growing them in containers this year so I can move the sun hungry plants to optimize how much sun they get each day.
v2500burb
Jay
v2500
350ci
That is what I as told to run
So if it's an issue SeaFoam will be paying for repairs.
cedens
Oklahoma
Cliff
305 4bbl
I always ran lucas oil fuel system cleaner and did add a quart of their oil system treatment. Also find a filling station that sells 100% gasoline... no added Ethanol or Naptha, one draws moisture one corrodes metal
raylanr
Campeche, MEX
Franc
The crew cab is rolling and she just pass inspection!
Shout out to Retro for the time and patience with both the truck and me!
datto62073
Monroe
Mark
found out i need new manual hubs. i have at least one broken one and i am not happy.
v2500burb
Jay
v2500
350ci
Trying to figure out how to keep my mirrors from moving
EVERY time I get in the truck the mirrors have gotten out of adjustment
Help!!!
cbrodine
NW Ohio
Collin
C25
Installed all new brake lines front to back and a new disc/disc prop valve, new fuel line front to back as well as new tranny cooler lines. I bought a 8 pc complete brake line kit along with the fuel line and tranny cooler lines from Inline Tube...
datto62073
Monroe
Mark
new Warn hubs..... not fun... but when my spicers are broken, gotta do something.
**** happens. If you get 20 years outta these new Warns then it'll be worth it. :waytogo:
wilson79
