My wife sewed up a new seat cover and we installed that after I patched the giant worn hole in the foam.
Installed new carpet sinse it had the old stuff removed before I bought the truck.
Reinstalled the freshly covered seat.
Rebuilt the steering column. All the tilt bolts were loose or completly out and the shifter drum was broken and missing a big piece along with a worn out ignition switch.
Bought another tilt column that came with the keys that was also falling apart for $20.00 and used the good parts from it to rebuild mine. The ignition switch was brand new. Rusty is coming along.
Sounds like a hell of a deal. I need to bite the bullet and do the same on my K1500. Also has the notorious tilt column with the loose bolts and can play ring around the rosey wiht the steering wheel.
Brandon_l1000
Tennessee
Brandon
350/sm465/np205
figured i would show you guys what i did to the old girl this morning. ignore the trash i have to take it off lol.
before
after
Rockstargraphics
Oshawa, Ontario
1500 Wrangler
5.7L
I chopped mine in half!!
[/IMG]
My phucking left turn self cancelling phucking broke. :(
[/IMG]
So what, you think that's cool??? I"m about to blow mine all the way to hell and into a million fuggin pieces if I don't get the fuggin Temp gauge working !!!
:laughing1:
And hell yes, I'll be getting pics and video when I do it too. !!! :rofl:
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
It's usually the springs. You can buy the springs for like $2 in the !HELP section at the auto parts store. Turn signal cam is like $8 or so. Simple to get to, just have to pull the wheel and remove the lock plate. You've done that before, so it should be cake. :whip:
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
:laughing1:
you didn't use teflon tape on the sender did you? have you tried a aftermarket gauge? :deal:
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
throttle plate re bushed, valves adjusted, timming bumped to 12 btdc. runs great, but still a fuggin miss out the tail pipe. :( welded my steering shaft, fab a block of plate for my egr valve, changed oil and filter and testing some of this out.
Rockstargraphics
Oshawa, Ontario
1500 Wrangler
5.7L
:laughing1:
I would like a personal copy! :):signs1:
Rockstargraphics
Oshawa, Ontario
1500 Wrangler
5.7L
STILL CHOPPING!!!
107 days.... :popcorn:
chevydude
arizona
hunt
k20
grinded of all of the spring hanger brackets Today I am going to mount the whole rear axle leaf springs and all.
Corneel
