Dejure
Eastern Washington
Kelly
C15
Hmm. Was wondering what I should do with the ash tray slot. It might be a good place to put a tire pressure readout AND USB ports. . . . Actually a pretty simple 3-D print.
SIDE NOTE: May try some ASA filament. Got in the truck yesterday and noted the prototype PLA prints were molding themselves to the seat belt via the rolled up windows in the 100 degree heat.
hmm....be nice to put some digital displays in there for other sensors to display. I've got a small analog tach in there now. Sorry, thinking outside of the box.
Ajax19
Socal
Ajax
good time to put the relay harness on your headlights as well.
Is that a common mod? I'm running 5x7 leds for a few years now but I haven't had any issues until now re routing that red wire fixed the problem I had a similar thing with the alternator sensing wire rerouted it to the battery better than digging through that 40 year old harness lol plus makes it easier to repair
Camar068
Air Force Supporting Member
10 yrs Air Force
yes it is. The lights will draw power directly from the battery and not the trucks harness. You current power to your lights would then be a signal to the relays. Less power through your trucks aging wiring. Higher voltage directly from battery compared to old harness.
My truck was dropping about 2 volts to the headlights. Brighter lights for sure.
Ajax19
Socal
Ajax
I have plans to add a fuse/relay box for all my other lights so I'll add that in then
84_c10_GMC
Alex
Transmission is in. Need put top 2 bell housing bolts in but need get dip stick tube in and wire harness hold down flipped down. Then converter bolts and put the passenger side exhaust back on. Starter and cover. Next will be make sure the driveshaft I bought fits, and get new u joints.
Got venison meatloaf about to come off the smoker and beer coming shortly and will call it a night.
Marine Corps Moderator
Got the motor and transmission in. Cleaned up the core support. Drilled the spot welds out on the brake booster/steering column mount Cleaned it up. Started mock-up on the shaved firewall panel
DatKat933
Bremerton, WA
Anthony
SBC 350
Friday I purchased a set of used tires with black Rally wheels with a good set of chrome beauty rings. Today I got them installed. I suddenly realized that while surfing FB Marketplace, I had gone full potato and bought 31s instead of 32s. O well, the black wheels still look good (in my opinion)!
code75
