What can cause a backfire?
coachdtierney54
US
C30
I live on a mountain. Whenever I coast down the mountain I hear several popping noises coming from the exhaust. Once I slow down to about 35-40 mph, it stops. It's an 85 C30 with a 454. I have tried to retune the carb thinking it may be running too rich, but that did not help. Could it be a timing issue? Any ideas?
Finally, thanks to all that have given me some great advice over the last few months! You guys are amazing!
Sent from my XT1254 using Tapatalk
74 Shortbed
You have an exhaust leak somewhere.
coachdtierney54
US
C30
I recently replaced the header gaskets and I do not hear the usual hissing from them.
74 Shortbed
May not be at the header gaskets, could be anywhere and very slight and not heard in the cab, need to run it on stands and get underneath and listen for it.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Could also be a bad plug or plug wire...an intermittent electrical issue. Cross plug wires will also cause a timing/backfire as well. (Don't ask me how I know that....)
coachdtierney54
US
C30
Plugs and wires were changed when I replaced the header gaskets
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Lean condition with fuel can cause exhaust backfire. In my cases, I've experienced that usually in acceleration though.
Also timing issues such as too retarded.
Another way to check for exhaust leaks is to jack it up, run it, and with a buddy... cover the tailpipe intermittently with a rag. This obviously pushes exhaust through the leaks, and sometimes easier to find. Look for soot on the exhaust, this is where it'll be leaking.
Those are just a few issues that can cause the exhaust to backfire ... the intake can backfire too.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Valve float when using the engine as a brake.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Or you can stick a vacuum cleaner wand in the tailpipe and put a rag around it. You just can't leave it in there for long, or you'll overheat the motor.
87scotty
Central il
Andrew
V20
5.7 for now
i always though that was a good sound when engine braking a little cackle in the exhaust
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Yeah, like it can blow the muffler right off the vehicle, lol..
Then you'll just increase the efficiency of the engine and drop a few lbs. Sounds like a win-win to me.
coachdtierney54
US
C30
Drove it a lot today, it's getting worse.
ruggedly
