What ate my front u joints? Dana 44
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Also please consider driving style. The more the front wheels are turned (steered), the less loud pedal you will feed them. The U joints become seriously weaker every degree they get opened.
The Right side of Washington
Have you quit pontificating on u joint and grease brands yet?
Reading all these posts about grease.
Something else that might be amiss.
When You installed the new u-joints and got them all pressed into the shaft and retainers installed.
did You center them in the shafts ?
More U-Joints gets destroyed because people dont know about centering them.
i have not installed any ujoints myself but wouldnt be surprised if i would make that mistake soon when i do them
do tell
I’ll take it, by your stuck in the mud and no 4wd thread that the answer is no.
Oh no I was stuck and unable to shift into 4wd not a broken drive shaft. it still works and is still unrepaired. so is the motor mounts and spring etc etc.
I am cleaning up outside in preparation for winter today and trying to get the trailer done so garbo hauling can be done. then i have to fix a radius arm bushing on the f150.. again... then i can clean a spot in the shed to pull the truck in and get to desparately needed work.
I waited for the ground to firm up, put a chain and slipped it under the tires, and crawled it out.
^ Cool. That works.
Another good traction mat in mud is that orange construction fencing. Have crawled a couple pickups out of mud holes with that stuff.
Joestreml
