What’s this Connector
87silveradok20
Ohio
Levi
Silverado k20
It’s under the dash and has a pink/black wire and a purple wire
87silveradok20
Ohio
Levi
Silverado k20
I also have figured out that the pink/black wire has power when the ignition is on
gmachinz
Harnessworx Inc
Iowa
Jabin
Cruise control switch off the bracket above the accelerator pedal
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
It's on the cruise control switch, but it's used for TCC shutdown when on the brakes, isn't it? Or maybe I'm just confusing myself, since that's what I'm using it for on my LS swap.
gmachinz
Harnessworx Inc
Iowa
Jabin
Correct.
Yeah, that's right. And it's only necessary with 700r4 (MD8) applications:
87silveradok20
Ohio
Levi
Silverado k20
ok, so since I have a th400 it is not needed?
Nope, TH400s don't have lockup.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
Not sure about tire burning with that taller first gear but they are reliable. Does anyone know if when they made the 4l80E they kept the same first gear ratio or did they match it to the 4l60E?
74 Shortbed
4L60E= 3.06 1.62 1.00 0.70 2.29
4L80E= 2.48 1.48 1.00 0.75 2.08
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
A TH400 and a4L80 have the same ratios up until OD
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
malibuman402
nc
Larry
C10 Silverado
BB 402+.060 = 413.8CI
