water or coolent leaking 350 TBI don't know problem
K5Blazerboy87
Tacoma Wa
Kyle
K5 Blazer Silverado
I was coming home from football game parked my truck turned off and heard water dripping and it was just dripping lots of water or coolent and I recently changed waterpump it's coming from behind power steering unit but it's not coming from water pump or hoses can anyone have idea what it's cause its my everyday driver
In the spirit of not making myself look dumb by guessing, if I were you, I'd try to borrow a coolant pressure tester from Autozone, fill the radiator with water, pump it up to sixteen pounds and go to looking for the leak. If it's hard to see, I'd add ultraviolet dye and try to find it with a UV light. Ahh, what the hell. I'll venture a guess. Might be where the pump mounts to the block on the driver side. Did you use both the seals that came in the box and a coat of RTV?
K5Blazerboy87
Tacoma Wa
Kyle
K5 Blazer Silverado
Yeah I did it's coming from behind power steering pump by there it's not the water pump mounts
Hmm, could it be a freeze plug?
1973c10
Don
I would check the freeze plug behind power steering pump
K5Blazerboy87
Tacoma Wa
Kyle
K5 Blazer Silverado
That's what I'm thinking it is it might be do freeze plugs go out I'd they do do they leak alot if antifreeze
77 K20
Montana
K20 5" lift
HT383 fuel injected
Or do you have an engine block heater on that? I've had them leak then ultimately blow right out of the block and I lost all my coolant. I was 15 at the time...
K5Blazerboy87
Tacoma Wa
Kyle
K5 Blazer Silverado
Um idk if I do all I know is the antifreeze is coming from behind up by my power steering unit idk if 350 TBI had those but I know what your talking about but idk if that would be the problem or where it was located
77 K20
Montana
K20 5" lift
HT383 fuel injected
Do you have a power cord sticking out of the front of your Blazer anywhere? If so then follow it back and it will lead you to the block heater. It would be behind the power steering pump.
Dons79C10
