Wanted C20-or C30
Blackdog3
Lansdale, Pa
Silverado K30
5.9 Cummins
Hey Gang, I am looking for a 81-87 C20 or C30 truck. I have a spare frame and axles lying around from my attempt of restoring a 81 K20. I scraped everything because the body was so bad and need a complete truck with a title.! Keep you eyes peeled!
Thanks
Keep an eye on the CL thread dude, if I see anything from around here I will post it. Me and the daughter were on there yesterday looking for c-10;s, k-10's and k5's. I am trying to brain wash her, lol. Didn;t look for anything heavier than a half ton at the time.
Blackdog3
Lansdale, Pa
Silverado K30
5.9 Cummins
I have been looking John on CL... its rough because people dont list stuff properly. I was looking at a C10 from delware for 600 bucks but i really want a higher gvw truck to match the K20 frame.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
What is your price range?
If you were able to get a rust free $300-500 truck from here shipped there or able to just come get it, you would probably be money ahead than trying to fix a rust pile from up there unless you get lucky. :)
davbell22602
Bunker Hill, WV
I Dont
Have
One
Shaggy might sell his c30 dually to ya.
Blackdog3
Lansdale, Pa
Silverado K30
5.9 Cummins
It all depends on the price... 300-500 bucks sounds great! IT would awesome if the thing ran before swapped the bodies over... might make it easier. I know texas is a long trip, but it might be meant to be... considering i just bought a big tex 10K trailer! Either way keep you eyes posted!
RetroC10Sport
Jay
pontiac aztek
You got it. With scrap prices up, they've been hard to find, but not impossible. I have seen quite a few C20s and 30s for under $500 though. :waytogo:
davbell22602
Bunker Hill, WV
I Dont
Have
One
Not in my town. Cheapest I seen a squarebody truck in any weight is $500.
So you're wanting to swap a C20 or C30 body to your 8 K20 frame? So any body, C10 thru C30 should work right? And even K10-K30 would work too shouldn't it? I hope you kept the center hump out of your 81 K20 cab. You'll need it if you're puting a C cab on your K frame. Higher hump on the K models to make room for the T case so you'd have to cut the K hump out of the truck to weld in the C cab.
Blackdog3
Lansdale, Pa
Silverado K30
5.9 Cummins
Ah damn it, I didnt keep it... But i figured I would try to get a C20 or C30 for the higher GVW... emission exempt . IF i got a body lift would that help not having that center hump deal.
Ahh yes, you know exactly what you're doing as far as the C20. I am doing the exact same thing. I have a K10 and I am swaping a C20 cab onto the frame that I have the title for. This gets me away from having a Cat too, so even if OK does go to emissions testing, I am in the clear. I also intend to run the 8 lug axles and 14b full float rear end.
Yes, if you do a body lift you can get by without the high hump, but keep in mind it'll make your T case shifter a long reach which usually isn't a bid deal, and you could actually extend or modify the shifter stick too.
This 85K10 I have, I've been told it's worth gold in CA cuz it was originally a 6.2 Diesal and Diesal is exempt from smog in CA. I do have the title to that cab but its been signed and not notarized, so I'd be better off to pay the $100 for a Title 42 and get all new paperwork on it to bring it current. Its normally $50, but this vehicle is titled in KS, so its $50 more for an out of state vehicle. If I thought I could really get gold for it, then I'd pay the $100 to get it done, but who knows. I just know for now the plan is to put the 85 C20 cab on the 85K10 frame.
Camo
mobile
1500 extended cab 4x4
4.8 V8
body lift helps But the center hump is the right way to go. I had to weld in the center hump in the crew in my signature. Took about 30 minutes. better than body lift.
A agree, the center hump is the best way to go. Maybe you can cut one out with cordless saw at a Pull a Part.
Blackdog3
Lansdale, Pa
Silverado K30
5.9 Cummins
Dont they on bolt also> It seemed the one in that 81 K20 i scrapped did? Unless it was special.
Not all do, but I have seen that are bolt on. I don't know what depicts if it got bolt on or not. Whether it was Manual trans 4x4, or all manual trans 2 and 4 wheel, or if it was just paticular years or not. Have no clue, but the bolt ons are nice, but I have seen enough of them to call them common. More common to see the hump is just part of the cab.
Twistedwhisky
