vortec heads
4thgentruck
South Carolina
c10 shortbed stepside.
Well gave it alot of thought and decided to do the vortec swap. Went to the local u-pull-it found a 99' 3500 and got the heads off. The stamping is 906. Gonna slap em on my 400 sbc. Cant wait.
91burb
South Carolina
Kris
Have them checked for cracks. Vortecs are bad about cracking. Went thru 3 sets before I gave up.
Watch your lift anything above 450 - 470 and its a waste
77 K20
Montana
K20 5" lift
HT383 fuel injected
And if I remember right I think you need to have "steam holes" machined into those heads for your 400. Maybe someone else can add some detail.
4thgentruck
South Carolina
I got a machine shop close by that is going to do it and the motor for around 250, that includes boring if needed. But they were only 35 a head at the u-pull-it here so if they are cracked no biggie.
And I will need steam holes drilled in them. Anything other than a stock 400 head you will need to get them done.
Im also gonna have the hardened exhaust seats removed while hes got them apart for alil potring and better flow.
1986K5Wa
Washington
Walt
I've been thinking of doing this to mine. But I have a 454 L19 and don't know what heads I would need. I've seen some posted on CL.
4thgentruck
South Carolina
Big Blocks I have no Idea about. Maybe Hotrod can help out or another member . Im just now getting into all this.
But if its a good deal and they arent cracked or bad go for it. Im sure youll tell a big diff.
4thgentruck
South Carolina
Besides All you have to do is start you a thread and youll find out anything you want to know and more. Thats how I ended up doing the vortec 400 build.
grayson1210
