Valve Cover Spec
Boone83K10
Boone, NC
Benjamin
Today after work I will be installing my new valve covers that I bought from Summit. It came with T-bolts and spreaders. What would be the correct torque specs? Finger tight? I read that 3 ft-lbs is the recommended amount of torque. Well that will be hard to do with the T-bolts.
I also assume I should tighten in a cross pattern.
You kind of just feel it. If it's stamped covers, just make sure the flange doesn't distort when you tighten them.
GM spec (for cork) is:
Valve Cover Bolts 65 in.lb = about 5-6 ft/lbs.
Most important is to make sure you install the spreaders correctly. If you have a set of OEM spreaders, look at them closely. You'll notice that they are not flat - they are cupped.
Install them so that they are concave down (convex up). The construction of the valve covers - thin sheet metal and minimal fasteners- makes it hard to keep a tight seal throughout the operating temperature range. The spreaders are cupped to help maintain a constant spring load on the valve cover flange.
If you haven't already done so, go out and buy a set of PermaDryPlus gaskets. I have used them exclusively for a few years and never get even the slightest leak. Insructions say to install them dry, no sealant and no adhesive. But for ease of removal I use a thin bead of silicone on the valve cover side. They have compression limiters at each bolt hole. Makes tightening them foolproof - using only your fingers just reef down as hard as you can. Go back around and retighten after a couple of weeks. Use 1/4" stainless steel lock washers under the t-bolt faces to help maintain torque.
:popcorn:
Boone83K10
Boone, NC
Benjamin
Ok guys installed them last night. It was a real pain to get the old dried cork gaskets off. I put the Fel-pro gaskets on. The hold down spreaders are about 4 inches wide and it came with studs to screw down the T bolts onto. No more leaking!
Now I need to figure out why my #2 cyl spark plug is sooty black. It's the only one that is like that. I suspect that buying the truck at 500 ft altitude and I live at 3500 has something to do with it. But only one????
Hard
