V2500 4in lift replacement? ORD?
Girth
Olympia WA
Garth
V2500 Suburban
Backstory....
Having just gotten the wife's Burb back on the road after it's Winter refresh, I drove it to work last week...... and jeebus does it drive like a pig. lol Yeah yeah, lifted square, I don't expect a Cadillac, but dang. It STEERS fine (new Redhead box, all new tie rods, replaced the raised steering arm since the one they had on there was a bit shorter than the Superlift one I put on to flatten out that steering rod) but just rides like garbage and wallows all over the road. The tires likely aren't helping (silly big wheels), but any "whoop" in the road and it's almost a guess as to which direction it wants to go. Steering is positive, but you still gotta row it sometimes. There's a 4in Rough Country lift on there now, which wouldn't have been my choice, but that's how it came to us. Front spring packs are starting to splay out, a couple leafs drifting out to the sides, and the rears aren't a lot better.
Sometime this Summer, the SF 14bolt is come out from under it, so I figured that'd be a perfect time to improve on the suspension. The trick is..... that 14B is getting replaced with a DRW D70HD, new fenders and all. Dually conversion. (Just gonna add the arrowcraft? Dually hub spacers to the front).
It's an around town rig mostly. Haven't towed anything yet, but I don't wanna lose the ability. I fired off an email to ORD today, asking what they had/would suggest for a truck setup like that. I'm sure it won't be cheap, but if I'm gonna bust my knuckles and bleed on the truck, I want to do it once and be happy with the end result.
Anyone running ORD lifts on their trucks, or have a better idea? A 3/4ton Dually Suburban is probably a less common creature lol, but a general consensus on quality vs value will help. It's "only" a 4in, and will wear at most a 35in tire...... but is the switch to crossover steering THAT worth it?
Pic of "Beastie" for attention....
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
:popcorn:
Following along!
Edelbrock
Earth
Grumba
K5 Blazer
Nice ride. I would go with a different style of army boots though.
Chris64
San Diego
I wonder the same thing. It becomes costly by the time you get the 2wd steering box and either a new machined knuckle or find someone who can machine yours. Also I've seen a few YouTube's where the parts they buy give zero clearance for the oil pan.
If it only helps bump steer I'm not sure it's for me. My concern is the 20 degrees of dead wheel that I can't get rid of (it's not the rag joint or steering column).
Girth
Olympia WA
Garth
V2500 Suburban
I assume you mean the wheels? Why does everyone focus on that? Yes I know they're hideous. Some dumb kid bought them, they're what came on it. As I said, it's getting a dually conversion, so it's gonna have SIX different wheels and tires soon enough.
Girth
Olympia WA
Garth
V2500 Suburban
Yeah, it has a BIT of bump steer, but hardly noticeable. That I can manage. Some of it's wandering, at least at freeway speeds, is those silly tires too, tramlining. It just WALLOWS, and rides like garbage. Hard to explain.....
Oil pan interference? I think I saw ORD has two crossover kits? The normal crossover kit, and the high steer option? Guessing the high steer is where the issues lie?
20 degrees of dead wheel!? :oops: If it's not in the shaft, gotta be in the steering box, otherwise you'd spot one of the links moving in a very obvious and bad way. lol Maybe try laying on the ground and watch the pitman arm, while you have someone turn the wheel back and forth lock to lock? The "remanufactured" box that was on this one was TRASH. Had my wife turn the wheel for me. Going one direction, I could see the box shaft turn AND slowly retract up into the box. Start turning back the other direction, and it would DROP down on its way back. :oops: A rebuilt box from Redhead made a big difference, but I also went though the rest of the steering. (It was BAD when we got it. lol) Swapping the steering arm on the knuckle fixed some less than ideal geometry on that drag link from the pitman arm to the steering arm too. Rag joint, amazingly, has no movement in it.
Edelbrock
Earth
Grumba
K5 Blazer
  • stock-photo-old-worn-military-boots-women-s-white-shoes-on-wooden-floor-veteran-and-family-con...jpg
Girth
Olympia WA
Garth
V2500 Suburban
Well, the reply from ORD was them recommending their "custom" springs for the best ride. With that was a caution that they're soft springs, so they ride nice, but to retain better towing capability, they recommend air bags or something like them to handle additional load.
Kinda thinking I'm not into spending $3k or more on it. Gonna look at other options, though guessing there aren't many for the 3/4ton.
Spider
Montana
GMC and Chevy v2500 suburbans
5.7 tbi, 6.0
Just a thought, but a 4” shackle flip would keep your current ride feel. Love that burban. Mines a 90 gmc on 35s with 4” skyjackers in the rear. Rides like a 3/4 ton. I would have tried the flip if I’d known about it.
Chris64
San Diego
I dug into this a little tonight. I tightened the adjuster 1/4 turn at a time until the steering started to be a little resistant and then went back 1/4 turn. Still has about 4-5" of slop at the wheel (18"). The problem appears to be the steering arm that goes onto the splines. When you turn the wheel it deflects up and down before it even starts to turn.
So that's scary. I'll be taking that off tomorrow if it doesn't rain and figure out if the whole shaft is flopping around or if it's just the arm.
If it's the box, that might be a good opportunity to maybe go with the 2d version with a crossover though.
Old Guy Bill
KY
Bill
Check the frame area at the steering box bolt holes for cracks.
Old Guy Bill
KY
Bill
Are you sure the frame isn’t flexing due to cracks?
Backstory....
Even with rough riding springs and those big wheels that really aren't even that big, it should be capable of steering down the road nicely without a bunch of wandering.
Have you checked the alignment?
You aren't supposed to start adjusting the box with the sector lash adjuster. You are supposed to set the worm gear thrust from the front of the box. If the gear is moving forward and back when you turn the wheel it's not turning the pitman arm during that time. That's what was going on with the guy aboves box. I've got factory procedure somewhere I'll come back and add it.
Blazerbiker
Rifle CO
Stephen
K5, actually a Jimmy since it's a GMC
504in
With a dually rear end, trailering would seem to be a big concern so you'll want to keep at least the stock rear springs and maybe supplement them with airbags. The overhang on a burb makes tongue weight a big more of a problem than on longer trucks.
You could run a softer spring pack on the front which would help ride quality for the front seats at least.
blackbeard2011
