unable to keep engine timed
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
okay so my problem is timing the engine after I did intake gaskets
is the plate on the distributor that holds down the cap turns is it suppose to turn or not
chengny
Do you mean the distributor locking clamp?
The inner circle of the clamp fits up against the outer distributor shaft casing and on top of the shoulder.
With the lower surface of the shoulder sitting down in the machined bore of the intake manifold, the upper surface of that shoulder should be just above the level of the manifold.
When the clamp is tightened, it prsses the shoulder down into the bore and locks the distributor in place.
When its like that, the distributor should not be able to be turned.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
If you installed the clamp upside down, it wouldn't ever tighten up.
chengny
Or if the bolt is too long. Also, maybe if the gasket is missing the top of the shoulder might be lower than the intake manifold surface (I never checked that).
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
not the clamp I mean the part where the cap is screwed onto is what turns and Im not sure if it should do that
BigAl285
Wisconsin
Allan
383 S.B.C
Do you have the cap on correctly? I'm not exactly sure what you mean. You referring to what you see like behind the carb or what's under the cap?
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
i mean what is under the cap that plate moves when you hold onto the distributor housing the plate moves and it looks like it should be locked in place and should move with the housing until the clamp is tight
So you're talking the base plate inside the distributor under the distributor cap? I"m wondering if your talking about the Vacuum advance? :shrug:
BigAl285
Wisconsin
Allan
383 S.B.C
Those 2 plates are for the vacuum advance and will move some. If I remember right there will be 2 springs that go from one plate to the other just underneath the rotor. In order to see them the rotor has to be taken off. They are small springs too. I can't describe it the best but they control when and how soon or late the advance comes with on. I messed wth my springs when I was on the dyno. the springs are about the size of a pencil eraser. Are you plugging your vacuum advance line going to the carb when you set your timing? Are you sure your on number 1 cylinder tdc?
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
I guess its the base plate I dont think I have vaccum advance since it is an 87 tbi engine if the base plate is where the ignition module is bolted to than that's the plate im talking about
That should not move at all, let me go look at mine....
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
okay thanks for the information went and bought a used distributor for 45$ and that plate doesn't move
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Holy ****! never heard of the base plate separating.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Me neither! Chewed off plenty of gears, wore out shafts, etc. never a loose plate.
Wacky
