Turn signal issues
chengny
I think you might only need to replace the canceling cam. Like this:
Never mind the extra cost, changing that switch is a wicked PITA! The cam is screwed to the switch and can be changed with the switch in place.
Here I am changing one a few years ago. I don't remember doing it, but the picture proves that I did:
I have a bunch of pictures showing how to access the cam - but it is not hard. Just pull the horn button and steering wheel. I think it's the first thing you'll see.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
quote: Here I am changing one a few years ago. I don't remember doing it, but the picture proves that I did:
You'll get used to forgetting things.
And I am also confident all he needs is the cancelling cam.
aGood'olBoy
Waterford Pennsylvania
Jeremiah
Well I need to put a new ignition cylinder in anyways. For some reason I thought there was return springs that attached to the cancelling cam to reset the turn signals. I don't know why I think this as I've never had one apart...
chengny
You're right, there are 2 springs used as you descibed. They are indicated below. You need to remove the ones you have now and transplant them into the new cam - they don't come with.
This is one of those items that is best to get from the JY. The OEM versions rarely fail and the aftermarket versions don't always fit/work right.
wilson79
