turbo charging ?
dusty1964
tremonton utah
dusty
has any one installed a turbo on there 350? . i do not want hot rod , 3 or 4 pounds of boost is the most i think it could handle. any tips or suggestions would be helpfull and what size of turbo you used ? my truck is a 1977 k20 . thank you
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
5 days and no reply, you might be on the wrong site
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Just saw this post. Yes, installed a Shelby Spearco system in 1982 on my '82 305 SBSS.
I also needed to add a waste gate, not shown in these pictures.
Depending on the weather and fuel 7- 9 lbs of boost
Green79Scottsdale
G.R. - MI
Bob
When I read you only want 3-4 psi, I question why do it in the first place? Obviously more power, but heads and a cam will probably get you to the same power level.
Bennyt
Surprise
Ben
I'm not opposed to a turbo but its a lot of work for the minimal gains you are looking for.
I would look at a B&M or Weiand 144/142 roots supercharger. I have seen them used fairly cheap. I bought a polished B&M 144 in like new condition complete with all the brackets several years ago for $1250. You could run a big pulley and probably get 4-6 psi and improve your mpg by 1-2 if you aren't in it all the time and pick up 35-40 hp.
On my '89 GMC Jimmy, I used a Vortech s-trim kit that I got for $1500 used. I ran a big pulley and gave me 35hp at the rear wheels and picked up 2-3 mpg.
Turbo's are great if you have big money to build it right. However, unlike the supercharger kit, they aren't that easy to transfer from application to application and require custom piping, plumbing, etc. A small roots requires an intake change and pulleys and brackets.
