Griff
- Jul 19, 2018
- Thunder Bay
- Griffin
- K1500
- 350 sbc
Well yet another steering issue...
Truck won’t drive straight. First I thought it was just the beer. Even with just two it wanders so it’s nothing between the seat and the steering wheel.
I’ve replaced the upper+lower ball joints, tie rod, repacked the wheel bearings (they’re good), driveshaft u joints are good, new steering box and pitman arm, no crack in frame, drag link is tight, installed a Jeep driveshaft, all new rubber spring bushings, new calipers, new pads+shoes, tried it with and without the steering shock (surprisingly zero bump steer without it) and yet the problem still remains... 33x9.5” tires (for now), 6” suspension lift 3” body. I have shims under the leafs up front and thought maybe the castor is too close to vertical but both my friends with 6” lifts have the same shims and no problem. I guess taking the shims out might be worth a shot but I have a th350/np205 and my front driveshaft is already about as steep as I’d like it to be. Any other ideas? Thanks,
Griff
Griff
