Transmission Pan Question
Joeairforce
Maryville, TN
Joseph
V2500
6.2L N/A Diesel
Nope... I just get one of these for my stock pan.... Carquest is usually the only place that I can find that has them normally in stock.... and there less than $5...
Normally they work OK if you torque them properly and use a good gasket. I prefer the Neoprene gaskets over Cork/Rubber. Th350 even has some OEM pans with a drainplug, or get one of those parts that Joe suggests. If you're change is just for a drainplug, then no sense in spending a fortune.
towman
harrisburg pa
jay
v10
i put one on my 700r4 was around 70 dollars and from b&m, that was a few years ago, it holds an extra two quarts now wich was a bonus
I believe those B&M pans also have some small fins to help with cooling along with the extra 2 quarts so its worth it. Extra cooling will always let a trans last longer. And you get the added benefit of a trans drainplug.
towman
harrisburg pa
jay
v10
you are correct has small fins to help with cooling
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
You dont have to pay their full price on stuff Dave, Jegs and Summit and many other places carry their stuff for less.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
if i ever have a chrome pan, the first thing i do is sand the chrome off of the sealing surface, otherwise, they leak. same with valve covers, oil pans, or timing chain covers.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Really?
Stickman
