Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
I just got a email from TransGo promoting a transbrake valve body kit that retains automatic shifts for the 4L80. After reading the instructions, it appears you can set the brake is first gear, and then manually shift it, or set the brake in D3, it will then go thru the gears normally once the brake is released.
I might have to look into this!!
