Transfer Case Speedo Gear Question
MtBraun
South Dakota
Up until today the speedo has not worked in my 78 k15. I have scrounged a gauge panel/speedo from a 74 2wd, and a cable from a 84 K10. It works but is measuring about 15mph slow in comparison to a gps. I pulled the driven gear and it is 18 teeth. It appears the only option is an external gear reducer?
I don't understand why its off in the first place. The truck has 2.76 gears and stock height 28" tires.
I also have a JTR speed sensor installed as part of the TBI conversion.
highdesertrange
kalifornia
mike
k30
do you have the ratio adapter installed or are you trying to put the cable straight to the transfer case? highdesertranger
MtBraun
South Dakota
I tried plugging the cable directly to the speed sensor, which is plugged to the TC. There was no speedo adaptor on the truck when we got it, so I assumed nothing was needed.
highdesertrange
kalifornia
mike
k30
a 1978 is supposed to have an external gear ratio adapter. highdesertranger
