Torque Converter, flex-plate cover
Preston
Mechanicsville VA
Preston
Hey I’m trying to find a supplier that sells the heavy duty cover for for my 84 K 10 the kind that the brace from the transfer case bolts to.
Thanks for the help.
QBuff02
Central IL
Quincy
@78C10BigTen still have that cover laying around.?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
The thick aluminum one?
My 84 K-10 has one, but the brackets go to the cover from the engine mounts.
The brace for the transfer case is a long arm that goes to a bolt on the bellhousing.
I MIGHT have a spare aluminum cover floating around, will look when I hobble outside again.
QBuff02
Central IL
Quincy
That's part of what he wants from the sounds of it. I remembered you having one awhile back. The complete setup has brackets that go under the engine mounts and the braces go from there down to the heavy duty cover, and then there would be a rod that goes from the passenger side of transfer case up to about the 3 o'clock mounting bolt on bellhousing. Sounds like he's just looking for the heavy duty cover itself. maybe the OP @Preston will chime in with what he needs exactly
Preston
Mechanicsville VA
Preston
Exactly what I’m looking for
Preston
Mechanicsville VA
Preston
I have the 2 piece motor mounts don’t have the ods that go to the cover either
Preston
Mechanicsville VA
Preston
If anyone has a picture of what all this looks like installed might help as well, I have bolted a 1985 350 engine to a transmission and transfer case from a 1989 looks like everything is going together okay so far
militaryjeep
chatsworth
steve
Suburban K20
These are from 5.7 with 4L60 it think.
I will sell or trade for one for 5.7 with 4L80E!
Misty Blue
