To Bare Metal or Not
bigge31566
GA
Ervin
I am restoring a 83 C10, and there isn't must rust on truck left, replaced cab corners, rocker panels . The fenders and bed don't have much rust just were paint got scratches. It though has about 2 different paint coats, do I need to take it to bare metal or just feather out spots and repaint
I went to bare metal on mine because it'd been painted previously at least once and not well at that.
HAZZARDJOHN
Medevial England Iowa
V1500
Unless it is laquer it shouldn't be that hard to strip. I would, because the little extra effort now will pay off huge in the end when you have peace of mind.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
if it only had the original paint I would just feather it and paint
but with a couple paint jobs on it you never know how good of prep work they done and it may cause problems
bigge31566
GA
Ervin
How would you go about stripping would you use a chemical, or sand to bare, any suggestions would be helpful
tnsser
knoxville
michael
Remove with a grinder and paint removal pad. I wouldn't use chemicals unless it is lac
quer.
I went to AutoZone and picked up a wheel of sorts that is for stripping paint. I'll have to see if I can locate a link but it just attached to a drill and I went to town.
EDIT: I found a link to what I used. You can find these at almost any auto parts store but this will at least give you a part and a part number to give you an idea...
http://www.grainger.com/Grainger/3M...2EXZ5&ef_id=UaZfQgAABb8-WgT-:20130905142430:s
I used probably a handful of those for the entire truck.
Green79Scottsdale
G.R. - MI
Bob
I would agree with taking it to bare metal. Unless... you know for sure the kind of paint you plan to use will be compatible with what is currently on the truck. If are a guarantee compatible, I would just scuff the existing paint and paint over it. You will be safer totally stripping it, but you will also find all of the trucks hidden previous body sins when you strip it down.
I just read you are restoring it. In that case, I say for sure take it to bare metal. If your truck does have previous shoddy body work, you want to take care of it correctly now so it doesn't come back to bite you later in the restore.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Not sure if the '83s had that electrostatic primer or not. If so, I would definitely go down to bare metai.
Tyger13us
BFE,Ut
Jeff
450hp/357cid
Im not a pro in any respect,, but ive done many vettes,, camero's and trucks body work,, even though i hate it,, im a perfectionist........
But id never take a vehicle down to mettle,, except for fixing rust,, dents or repair panel's,, bondo wont stick to pre paint,, only bare 36 grit mettle,, as far as paint goes id only go down to the factory color/primer/sealer......
if ya go all the way to mettle? then use a sealer,, color sand it,, then prime it heavy,, color sand it again,, then shoot what ever of your liking....
im a laqure fan,, its patchable,, color sandable,, and buff-able, but its not dust friendly,, ya will see spyderwebs, amoron is a one shot paint, really tough, but not patch able if chiped,, its an epoxy paint,, im not to fond of enamel because of the orange-peel and not buffer/color sandable friendly,, but more scratch resistant than laqure......
like i said,, I aint a pro!,, but the few cars/trucks i have done have been to shows and got 95 out of 100 points for body work and paint,, and that was at the Dallas car show many years ago "81" and a 63 split window vette at the Santa Clara county Fair grounds cars show in San Jose Calif "87".....
A laqure black 67 ss camero........ i got the trophie someplace in a box the 63 split window was done in RED....
just my 2C.............
bigge31566
GA
Ervin
I plan on priming and sealing no matter how far I go and using a bc/cc, just did not know if it was only only small spots to go to bare metal, still deciding
Prof GMC
Irvine,Ky
K1500
I agree with Tyger, I have done my share of paint and body work also. No need to take the entire truck down to metal. If the panel looks good, and has been painted for some extended period of time, odds are that is was prepped properly to begin with. If you want to make the truck laser straight, block sand the entire truck. That will show you your low spots. Once you find the low spot, dig a little deeper and see what you find in that area. If you find filler, get rid of all of it, and refill with new body filler. Never ever put filler over old filler. Like Tyger said, "use 36 grit". After you get the body where you like it, shoot it with high build primer, and block sand until your tired of block sanding. I also like lacquer base coat/ clear coat. Remember that you yourself is normally the worst critic. If you make the paint job satisfy you, then it will knock the socks off everybody else. Good luck with it.
87R10_Cruising
