Tires/Wheels from newer Suburban to my 88 Suburban
geocrasher
Northern NV
Ryan
V1500
Howdy gents,
I need new tires, and I'd like to replace the fairly discolored/rusty factory steely's on my 88 Suburban 1/2 ton 4x4. 6 on 5.5 as far as I know.
I'm on a tight budget, and so I have had the idea that I'll find donor tires/wheels from something else being parted out by a private party or by an auto wrecker. From what I'm seeing, 265/70R17 was available on Suburbans as a stock option between 2001 and 2014. Would these be a good fit? My understanding is that newer rigs didn't have locking hubs, but rather just have a flange or direct axle drive of some sort. I have that big 3.5" diameter Warn locking hub, and so that's my biggest concern.
Thanks for any insights you may have!
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
I think the biggest concern would be spacing, or offset. I've seen newer model wheels on squarebody trucks and they look kind of tucked in the fender wells.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
If i remember correctly the 8 lug wheels from newer rigs (until 2012 or 2014? not sure) fit squarebodies, but 6 lug wheels stopped fitting after the introduction of the GMT400. The hub bore on newer wheels is too small. Offset and backspacing may be an issue as well if you decide to have newer wheels bored out.
idahovette
Weiser Idaho
Perry
K20-K10
I have a set of 04 wheels on my 75 K-20. They are kind of tucked , not any offset. But I had the old 8.75 -16.5 tires on it so this is a real improvement. Still have the original "mud grip" tires that came on my rig in 75, been stored inside and still look good ,but they only go on when the snow is a foot or so deep around here(10-20mphin town) Not to be trusted any where else!!
geocrasher
Northern NV
Ryan
V1500
Thanks guys! I didn't realize offset would be such an issue, but they DO look a lot deeper now that I'm looking closer.
At any rate, it's now moot. I just bought a nice set of 31" mudders from a guy who upgraded to 33's. Got them for a dang good price too!
Wilburn Martin
Northport, Alabama
Wilburn
C20 3+3
Might look at something off of a 90's Toyota. My 94 pickup has the same bolt pattern as my dad's 75 K10. May find something newer "fancier" aluminum. I just got a set of 16" aluminums for the tires for 200. They have cosmetic issues themselves but could be cleaned and painted cheap.
4WDKC
Southern Florida
Kacy
285/70/17 H2 wheels on rear and 33x12.50 gm rallys front, does that help you see the difference?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
The rallys win hands down, no contest.
4WDKC
Southern Florida
Kacy
I do like the rallys but they never came in 8 lug option and it was cheaper and wiser to swap in a 14bff and front axle than to regear the stock diff when I plan to haul a car, I also have been stripiing the black paint off the H2 wheels.
geocrasher
Northern NV
Ryan
V1500
I forgot to post a pic of what I ended up with! It rides a lot different with these mudders on it, but the price was right :)
Kyle Childress
Brownsville KY
Kyle
K20 silverado
I always wanted a set of truck rallys in a 8 lug, through they would look so good, favorite GM wheel, best looking one ever made in my opinion.
Dennis Blom
