Tire size on truck
kenn
detroit
ken
c10, k10
I have pro-comp all terrain tires 35x12.5x15 on 15x10 rims tires measure 33 1/2 tall on the truck, is this normal ? Please share your tire brand, size mounted on vechile I want new mud tires for my 4 inch lifted 1978 k10 old tires do not rub at all, want to keep it that way are all 35's going to be shorter like mine ?
73c20jim
Tombstone, AZ
Height also depends on air pressure.
77 K20
Montana
K20 5" lift
HT383 fuel injected
It's pretty much normal. The only way a tire measures "true to size" is when they are unmounted without weight on them.
Rusty Nail
Rusty
350sbc
It's cuz you haz 10s and your 35s are stretched. I bet you get a lot closer to 35" on 15 x 8s. even!
SO . It seems that it would stand to reckon that if you mounted the famed 37s on your 15x10s with no other changes , you would hit 35 inches on with a 4" lift.
Ready?
Go!
Camar068
Kentucky
10 yrs Air Force
31x10.5x15 on 15x10 = 28.75
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I run 44s on 16" wide rims and they measure out at 32" high...
come on you guys..
