Time to replace the flexplate
Simon
AZ
Simon
V2500
350 SBC 5.7
All set up and ready to go...again. Replaced the flexplate about 30 miles ago but my dumbass never torqued the bolts to specs and surprise, it cracked! Starting up again today, any advice would be greatly appreciated.
Simon
AZ
Simon
V2500
350 SBC 5.7
Main concern right now is step 1. Last time I did this it was in a level area so I didn’t have to worry about the truck moving when I yanked out the rear driveshaft. Now I’m on a bit of an incline. I’ve got the parking break set and I’m gonna chock the wheels. Feeling confident.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
A tranny jack is a good idea too. Helps it slide back easy without worrying about balancing it. Some guys will put all thread into to lower bell housing to block bolt holes before sliding the trans back. Supposed to help guide it back into place, but with a good trans jack it’s easy without the all thread trick.
Simon
AZ
Simon
V2500
350 SBC 5.7
She’s out! What I mistook for cracks appears to be a little oil splatter. So my flexplate is NOT cracked. I did notice a wiring harnesses was pinched between the engine and trans near the top of the bell housing. I believe the flexplate was hitting that causing the noise I was hearing.
wilson79
