Tilt Steering Column Talk
Anybody bebuid the tilt steering columns in these trucks or replaced parts?
My issue is a side to side looseness. The actual tilt joint is fine, no play. The whole actual column is moving side to side about an inch at the wheel, but up and down it is solid. I guess I should look where the column bolts to the dash???? Or where it meets the firewall? They play is somewhere under the dash, not at the tilt joint. :think:
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
A place to start is under the dash, but I'm willing to bet the bolts inside the column are loose like most every other GM tilt.
Is this the right diagram?
attachment.php
RetroC10Sport
Jay
pontiac aztek
Not really, as yours has the multifunction turn signal stalk.
RetroC10Sport
Jay
pontiac aztek
I'm going to try and adapt tilt and telescopic from another GM and I think I've figured out how to with it with the 4 spoke wheel...
From what to what, your Blazer? Or just SB's in general? :popcorn:
I'll take a closer look at mine and make sure it isn;t any mounting bolts on the outside of the column. At least I got an idea now what else could be wrong on the inside. :handshake:
78shortandwide
Denver
Tom
Need to quit using the steering wheel yo get in the truck. My dads 82 did the same thing it was the bolts behind the steering wheel.
Yes, that is a bad habit. One I get my stock size tires the need for me to do that will lessen I hope...
3dbello
