Tick at start-up
Andrew mh
Colorado
Andrew
I guess I need to figure out why mine is so low then. At idle its sitting at maybe 10 to 15. I dont know anything about the vehicle or motor so this should be fun.
firebane
Calgary, AB
Curtis
As an engine ages the tolerances become less and thus causing a drop in oil pressure.
Other things can be poor gaskets or something as simple as a worn out oil pump.
Andrew mh
Colorado
Andrew
K thanks. Would it be a good idea to double check and make sure the stock gauge is reading correct? Do they fail very often?
CSFJ
Definitely double check. If you have a mechanical pressure gauge you can hook up, do it. It's the best way to avoid spending money on unnecessary repairs.
Andrew mh
Colorado
Andrew
Where would I connect a mechanical gauge at?
chengny
Im wondering whats the oil pressure supposed to be at idle?
From the GM SBC specifications sheets:
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
so the ZERO i see at idle on a fully warmed engine is probably too low....could be the sending unit, haven't had a chance to try and hook my diagnostic mechanical gauge up yet..
where would be the best place to hook it up?
Skweegle89
Oklahoma
My mechanical gauge just got here today and I plan on hooking it up in place of the sending unit. Leaving the oil pressure switch on the T fitting and hooking the new gauge up where the sending unit was.
flyboy1100
UsA
me
k1500
That makes the most sense. I will do that my next week off perhaps
jake26104
