Throttle sticking
350chevy85
Pennsylvania
Kyle
v20
I recently obtained a 1985 c20 with a 5.7l 350 and had to rebuild the quadrajet carb im having a problem where i cant get the idle speed to stay at a normal rpm. Ive messed around with the idle screws and still cant get it to get lower then a medium rev. I can use my hand to pull the throttle all the way back against the idle screw and it will idle normally but once i use the gas peddle it wont go back to touching the idle screw i have changed the spring that pulls the throttle back when letting off the gas and it still wont go all the way against the idle screw. Any Suggestions would be very helpful thanks
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Check the throttle cable for frayed strands. Also did you have throttle bushings installed? They may be tight and not letting the throttle move freely enough.
If it has AC, make sure the idle kick-up solenoid isn't engaging when it's not supposed to. Recently happened on a customer's '84 C10.
350chevy85
Pennsylvania
Kyle
v20
I havent checked the cable yet so i dont know if its frayed or not but when i re built the carb i didnt replace any throttle bushing so either the ones in there are bad or its something else. As for the A/C idle kick up solenoid i dont believe there is one on the carb even though i have A/C in the truck. Also at high rpms i get pops as if its flooding, can that be an issue with float height or if not wat else could fix it
crazy4offroad
Curt
K-10
350/SM465/NP205
Could be a vacuum leak if the base gasket didn't seal good. Also if you accidentally bent a choke rod could cause it, but you would notice the choke plate closed. First thing I would check is for vacuum leaks.
sybau
