Frankenchevy
Proverbs 16:18
- Jan 3, 2018
- USA
- Jeremy
- Square
- CUCV
- Small
i want to get the correct manifold for a holley sniper efi to connect to vortec heads.
it's been said that dual plane manifolds without an air gap or spacer can have too much variance in AFR from one side of the manifold to the other. there are a few solutions. i can buy an air gap intake which is a little more expensive, i can buy a super common edelbrock performer from CL and mill an air gap or install a spacer to essentially achieve an "air gap".
either way, i think a shorter spacer helps with any of the above configurations for all over power. if you go long on the spacer, i'm aware that i'll sacrifice bottom end. i definitely do not want that. i've heard that .5-1" is pretty optimal for helping without losing bottom end. phenolic spacers okay versus aluminum?
can anyone verify any of this info? any positive experiences with the big name dual plane intake manifolds, specifically an "air gap" style?
don't want to spend a bunch of money on this part of the setup if i can help it. i can pick up a manifold on CL for next to nothing and a spacer is $30. but i'd rather spend a few hundred bucks and not get some sloppy casting on a cheap manifold. suggestions?
