Those wind/rain deflector thingys...
hey mister
North Coast
Marty
Last year I got a set of those smoke tinted window things.
Read the instructions and carefully positioned them, just right, before peeling off the sticky tape backing.
This truck has no A/C so it's always windows down and vents out to the stops....that is until the wing windows now hit those smoke plastic things. Well, buggers!
This past weeks heat wave has motivated me to carve out some relief areas in the plastic so the wing windows can swing out to the stops.
I'll tell ya, it ain't easy whittling on that stuff. And the temptation to take the 4" disc grinder to it, is hard to resist, but knowing that would end in disaster, kept me from doing that.
So rat tail file and sand paper was how it started out. That was very slow going, but nothing was getting destroyed either. I kept thinking, man, I need a tool that peels a tiny strip off at a time. On the passenger side it hit me...I went and grabbed my Vargus deburring tool. Used correctly you can peel a steel curl off the edge of a plate and smoke goes with it. They are a great tool and I've had a few.
It took a couple of attempts but soon cute long plastic curls were falling off.
Before I knew it, the passenger side was done...and nothing was destroyed either....which is a good thing.
It's been a few years since I bought a deburring tool and I have not looked up the cost, but not scratching glass or paint or melting the plastic might be worth the cost when compared to the damage.
I'm wondering if you can use a heat gun to warm the plastic up enough to massage it and make the room for the "wing swing".
hey mister
North Coast
Marty
I thought about a heat gun, but I wasn't sure I wanted a bump-out and to get plastic hot enuf to move needs about 300° (considering most plastic molds @ 350° -375°) and that requires gloves. Plastic hot enuf to move will pick up whatever glove pattern the gloves have...cotton fabric weave ot leather grain...it will transfer.
In other words, you end up with a rough grainy bubble....that you end up cutting off cause it's ugly.
At least that's my past experience with sheet plastic.
I know it's a trick they use on later model plastic inner fenders. I guess that would be a different type of plastic, I did not think of that.
Camar068
Air Force Supporting Member
10 yrs Air Force
few years ago when I went to install them on replacement doors, luckily I remembered they touched. So when I installed new ones on the replacement doors I opened the wings and changed the location of the deflectors as needed.
yevgenievich
Place
Name
Year
Model
Size
Back a while ago installing wind deflector on hood of 91, a bit of heat gun is all it took to make room for the hood ornament. Just need to be soft enough to manipulate, but not melt.
VTXRider
Langley, BC
Gerald
High Sierra K2500
A couple days ago, I had a chance to go down the road with the wings open again.
I am happy to report, everything is working just fine.
Yea...
Could you let me know if they reduce the wind noise with the windows down slightly? Looking at installing these to reduce some wind noise with the windows cracked and the lower cab vents open. I don't generally use the wing windows, but like to have the window cracked a bit and lower vents open to get more air flow into the cab. I don't have A/C so need the vents and windows open in warmer temps, but the wind noise gets annoying on longer trips. Thank you, much appreciated!
406chevy
