Thinking of swapping to ls
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
If I were to buy a wiring harness where would be a good place to get one? Psi?
Moderator Administrator
@foamypirate got a super nice one. Look in his build thread or maybe he'll chime in here
And here's the link to the company who did his harness
http://shop.bp-automotive.com/
Seriously, read through his entire thread and take notes. All of the info is in there ;)
dougbert
5535 feet in Utah Mountains
doug
K1500/nv4500/np241c/33x12.50x16/4.10 Gears 14BFF
5.3L - 2002 Silverado, rebuilt top end, long tube headers
beest
indiana
matt
beest
indiana
matt
Heres my swap in progress...
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
May possibly have found a engine and trans combo out of a 03 suburban motor has 180k on it can get both for 1k with harness and accessories
beest
indiana
matt
Sweet. I got my engine out of an 03 yukon. Thatll do ya fine. :)
Sent from my SM-G920P using Tapatalk
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
Would I be better off going ahead and getting a engine and trans that's already pulled? I found one with 131k supposedly out of a 06 Silverado. Or should I go with the 03 and pull it my self? The 03 the guy told me he thought it had 180k but the odometer was reading 248k
beest
indiana
matt
Its not hard to pull. The 06 will probobly by drive by wire, if that matters to you. On the mileage issue 131k sounds much better than 248k. The ls engines are pretty robust though. The advantage to pulling it youself is you can get all the bits and pieces you want from the donar.
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
The 03 is drive by wire as well but can't I change the intakes to adapt to the 02 and back cable drive? The 06 was involved in a wreck but it's already pulled out and everything they want 900 for it
beest
indiana
matt
I believe you can swap the intake out, you will need to have the pcm programmed for that. My engine is an 03 drive by cable.
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
Oh ok I thought in 03 they went to DBW maybe not but that's not to big of a deal I don't guess
beest
indiana
matt
There was some crossover in 03. I guess they had leftover parts. Lol
VFL1982
