"The Big 3 Upgrade"
8T6K5
AZ
L98 350 TPI
I took it as asking about all......
Driver4r
Nebraska
Trevor
k10,c20
My speakers are all toast in my truck.
Hahaha. No, my truck is sorry, a sorry assed rust bucket. :roflbow: :wave:
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
ok see the nominal wattage they are rated at? go any higher than that for any extended period of time and be prepared for disaster. if you havent bought amps yet id seriously buy some lower wattage ones and save some money, if not just be sure the amp gain is turned way down. just tryin to help here. also the lower wattage will decrease the need for huge gauge wires and electrical upgrades
For Amps or not, I'd still do the Big 3 upgrade. I see nothing but Win doing the upgrade. Everything should function better.
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
of course, i mostly meant the alternator. i dont need it for any reason but am doing the upgrade anyway like you said
8T6K5
AZ
L98 350 TPI
So I got around to doing this today and here is my story:
A few things about this pic: notice the neg batt to chassis ground is 12G wire and goes to the core support THEN to the frame, wtf? The pos batt to alt has a wire connector about 4" off the terminal? Pos batt to starter is black, changed it to red since aly wire is red too. Yes, the poss batt to amp wire is suspect and I will address that later.
picture.php
Another view of before without all the MSpaint...
picture.php
The battery terminals were good, just needed to be cleaned...
picture.php
Neg batt to Engine block was good so I left it alone. Neg batt to chassis
picture.php
Connection at alt before and after....
picture.php
picture.php
picture.php
picture.php
I wish I would've snapped a before pic here, but its almost a full 2A increase when at idle. Turned on high beams/aux lights/AC/cranked the stereo needle barely moved.
picture.php
With shipping total cost was $45. Not a bad deal if you ask me. I still intend to drop in a 140A alt, after I get these on.....
picture.php
Awesome. Big difference in the wiring too. Looks much better and safer.
Great job Jerry. I think you should copy that post and put up a write up for it in the tech write up forum. :)
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Thats where my Volt meter sits now...was going into the danger zone. Still fires up strong!
guitarfreak235
Spartanburg S.C.
Andrew
k10 c20
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
im not done with mine, but yea i put new wire to the core support then the chassis too, and battery to alternator. just need to do engine ground (which looks hard to reach) and the battery positive wire
Corneel
