TH350 oil level, engine off
WFarm
Central Virginia
K5 Blazer
I am planning to install a temperature sending unit in my TH350 and was leaning towards installing the unit in the 1/8” NPT pressure tap port, circled in yellow. With the engine off and tranny cold is this port above the fluid level ( assuming not overfilled) or will I need to drain fluid before removing the plug?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Installing a temp gauge in the case is useless, there is no fluid flow. All you will read is the temperature of the transmission case.
Put the sending unit in the pan.
hey mister
North Coast
Marty
Ditto.
Replacement oil pans are made with ports for temp probes.
ali_c20
Austria
Alexander
C20, K5
Moderator
I have to disagree here. While the test port may be a dead end, there is still flow of fluid with the trans in operation. Unless the th350 is somehow much different than a 700r4.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Here is a hydraulic schematic from a service manual.
As you can see, line pressure comes out of the pump, and tee into the pressure test port. It then continues to the manual valve. The test port is dead headed at the pipe plug.
Adding potential issues, I remember someone here trying to use the pressure tap for a temp gauge, and finding out after installation the shifter wouldn’t move. The temp gauge bottomed out in the case, the broken pieces of the sending unit fell down into the manual valve and locked it up solid.
Lastly, the case is the last place you want to use to monitor temp. It will be the slowest to warm, and slow to cool down. You want to monitor the fluid temp, not the case temp.
Moderator
Yes, it is a dead end flow path but unless that dead end path is crazy long before it tees into the circuit, there's going to be fluid going past and circulating the fluid in the test port passage.
I've never used a temp sender in the test port of a th350, but I have in a 700r4. In that case (no pun intended, lol) it worked perfectly fine and had no issues at all with the gauge displaying rapidly changing temperatures. It was obvious that it was reading fluid temperature and not case temperature.
Chevy 88
Canada
f7t6
GMC
Point this **** at your **** and you will know all. $15 and no installation needed.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I can’t speak regarding any GM transmissions, but the 46/47/48re Dodge transmissions have a temperature sensor that is part of the valve body electronics, so reading from the pan.
When I installed the Edge tuner, they supply another temp sender to install into a test port of the transmission. That is installed where they said to put it. I have both on the Moniter screen.
They read generally within 10°f of each other, sometimes 15°, sometimes they read the same. But never beyond that 15° delta.
WFarm
Central Virginia
K5 Blazer
Installed my aux transmission cooler today. After a leak check (none!) I drove it the same route I did when I first put the temp gauge in. New cooler made a significant difference, even with it being warmer. (85 outside). I plumbed it in per the diagram below btw.
I did paint the brackets I made black so they wouldn’t be noticeable behind the grill.
jw23655
