Mlcdc1
- Aug 19, 2016
- IN
- Matt
- C10
shifting issue with TH350-Shifts great until it gets warmed up and then intermittently will shift down into lower gear or not shift up after a stop. I had a rebuild on it about 2500 miles ago and returned to the transmission shop, had it checked and they say it’s working fine. I recently installed a new vacuum modulator is hopes that would correct the problem but it did not. I’ve checked the governor and it seems to be working as it should. I’m at a loss for what to do next and would welcome any input. Thanks.
